KSdomer's avatar
KSdomer
R6900P random disconnect
I have been having the same issue since the day I got the R6900P which is that it randomly drops and then reconnects. In this world of working from home, having to wait until it cycles through when you are mid sentence is not acceptable.
I have been having the same issue since I got it and customer service had be reboot it which worked until it didn't. I was away for a couple weeks and have just been dealing with it and didn't realize it is only supported for a couple months so now I have this annoying problem that never resolved because I didn't complain again soon enough.
And the kicker...as I was submitting this the first time, I got disconnected.
  • FURRYe38's avatar
    Does the internet LED turn amber when this happens?
    Anything on the router LEDs that show any indications?
    Do both wired and wireless devices get disconnected?
    Can you access the routers web page at all at 192.168.1.1 when this happens?
    • KSdomer's avatar
      KSdomer
      Hopefully these answer the questions:
      What Firmware version is currently loaded? v1.3.2.134
      What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Spectrum EU2251
      Does the internet LED turn amber when this happens? Unknown - will look at next time
      Anything on the router LEDs that show any indications? Unknown - will look at next time. I don't know that I have a baseline for what the other LEDs look like on a normal basis so I will have to look at it now and record it so I can compare.
      Do both wired and wireless devices get disconnected? Both wired and wireless
      Can you access the routers web page at all at 192.168.1.1 when this happens? I haven't tried. I only ever try to access via the mobile app and am not able to access them that way when it disconnects
      • FURRYe38's avatar
        Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
