Yamster2016
Nov 20, 2016Aspirant
R7000 & DM200 Setup
Hi, I have a R7000 and a DM200 and i am trying to set them up but having issues. When using my xbox one I am behind a port restricted NAT. If I set the DM200 as a modem only I am unable to co...
- Dec 29, 2016Dear James,
I've manager the problem in that way, so probably that was causing the problem!
Anyway, I still don't understand how I can check or personalize the connection parameters like the VCI and VPI, or the MTU, if the R7000 don't have a settimo page for them and the modem in bridge mode is unconfigurable :-O
That's just an explanation question, my problem is solved now!
JamesGL
Nov 22, 2016NETGEAR Employee Retired
Hi Yamster2016,
You have to set one device as the router in order to limit the NAT restriction. Two routers in one network will have a double NATTing that Xbox will not be able to work. If you configure the DM200 to bridge mode, set the ADSL setting on the R7000.
JamesGL
Community Team
Yamster2016
Nov 23, 2016Aspirant
Thanks for getting back to me, the problem with the DM200 in bridge mode is i cant set the ADSL setting so i am getting odd gaming lag. I seem to be behind the game play.
- JamesGLNov 24, 2016NETGEAR Employee Retired
Hi Yamster2016,
Have you tried configuring your DSL on the R7000 page?
JamesGL
Community Team
- JamesGLNov 27, 2016NETGEAR Employee Retired
Hi Yamster2016,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
JamesGL
Community Team
