Yamster2016
Nov 20, 2016Aspirant
R7000 & DM200 Setup
Hi, I have a R7000 and a DM200 and i am trying to set them up but having issues. When using my xbox one I am behind a port restricted NAT. If I set the DM200 as a modem only I am unable to co...
- Dec 29, 2016Dear James,
I've manager the problem in that way, so probably that was causing the problem!
Anyway, I still don't understand how I can check or personalize the connection parameters like the VCI and VPI, or the MTU, if the R7000 don't have a settimo page for them and the modem in bridge mode is unconfigurable :-O
That's just an explanation question, my problem is solved now!
Yamster2016
Nov 23, 2016Aspirant
Thanks for getting back to me, the problem with the DM200 in bridge mode is i cant set the ADSL setting so i am getting odd gaming lag. I seem to be behind the game play.
JamesGL
Nov 24, 2016NETGEAR Employee Retired
Hi Yamster2016,
Have you tried configuring your DSL on the R7000 page?
JamesGL
Community Team
