Yamster2016
Nov 20, 2016Aspirant
R7000 & DM200 Setup
Hi, I have a R7000 and a DM200 and i am trying to set them up but having issues. When using my xbox one I am behind a port restricted NAT. If I set the DM200 as a modem only I am unable to co...
- Dec 30, 2016Dear James,
I've manager the problem in that way, so probably that was causing the problem!
Anyway, I still don't understand how I can check or personalize the connection parameters like the VCI and VPI, or the MTU, if the R7000 don't have a settimo page for them and the modem in bridge mode is unconfigurable :-O
That's just an explanation question, my problem is solved now!
AndyTheAngel
Dec 30, 2016Aspirant
Dear James,
