sktn77a
Feb 28, 2025Virtuoso
R7000 2.4 GHz performance hit
Recently updated to the latest R7000 firmware V1.0.12.216_10.2.122. Around the same time (don't remember if it exactly coincided with the update) my 2.4GHs speeds have tanked. I'm only getting about 100mbps on 2.4GHz versus 600mbps on 5GHz and ethernet. This is happening on ALL FOUR of my R7000 routers in my main home. Anybody else experiencing the same?
It may be less than wonderful, but that's not a dreadful speed on some 2.4 GHz devices. Which ones do you own? Are they all the same? What speed did you get before the update?
5 GHz and wired are faster by design.
Did you reset and reconfigure the router? You shouldn't need to do that, but sometimes it helps.
What modem/gateway/ONT feeds the R7000?
This is happening on ALL FOUR of my R7000 routers in my main home.What sort of network needs four routers? (What size mansion are you feeding?) How are they connected? I hope that at least some of them are set up as access points.
The R7000 is now more than a decade old. A decent middle of the road router in its day, but now a bit long in the tooth.
Disclaimer: Just another user with time on their hands.
- sktn77aVirtuoso
It's coming in through a cable modem that delivers 600mbps. I used to get much faster 2.4GHz speeds with a dual and tri band client (Lenovo T460) and with my iPhone 15 Pro. The fact that it's doing this on all 4 routers makes me think it's not a hardware failure but rather a software/firmware issue (it's not like this hasn't happened before with Netgear updates)!
đ€Ł
I've never seen sustained speeds on an AC router over 100mpbs. Occassional peaks maybe but not sustained. 2.4ghz is s slow network and sensitive to interference. Not sure how you were testing before but it wasn't until AX that we started seeing that 100mpbs 2.4ghz speeds.
