Mister-X
Jul 19, 2019Guide
R7000 5G
For those of you having trouble with 5G Signals, within my settings I have Enable 20/40 MHz Coexistenceunchecked(meaning Off), QoS is unchecked(Off) but WMM should be checked(meaning On) because WMM is needed for 5G Bandwidth to work properly. I also suggest you go into the NETGEARgenie and use the WiFi Analytics Button under the Connect WiFi Tab(NETGEAR>WiFi Connection>>Connect WiFi>>>WiFi Analytics). There you should look at the Channel Interference Tab(Signal and Channel Graphs may be helpful as well) and see what Channels it shows as being best for your network. It's a very useful tool and should be utilized to help you choose your Channels manually(NETGEARgenie>WiFi Connection>>WiFi Channel>>>Change Channel).
The Router has worked very well for me with these settings using Firmware V1.0.9.64_10.2.64, it's probably been at its best! For now, I will have to hold off on using the V1.0.9.88_10.2.88 Firmware because of a Speed issue I encountered when upgrading to this current version. The radio Signal seemed to be more stable but the Speed(s) seemed to be affected. Speed was significantly slower by about 75 Mbps within the 5G Bandwidth via WiFi. I am not sure as to why this is occuring. However, after reverting to V1.0.9.64_10.2.64, everything works fine again without any issues and it's back to top speed(s).
Hope this helps!
Go to https://www.netgear.com/support/product/r7000.aspx#download
and click at the plus sign on lower left that says "View Previous Versions"
- Thanks. I'll try this out. Mine has been a disaster for the last few days, but only with the 5g band. 2.4 is running great.
But really quickly, how do I find the driver to roll back to?- microchip8Master
- Awesome. Thank you.
- Mister-XGuide
Try this link, it's from Netgear itself: https://kb.netgear.com/000060566/R7000-Firmware-Version-1-0-9-64
After becoming aware of a New Firmware Upgrade being available, I go to Netgear.com>Support>>Type in R7000 in the Search>>Downloads>>> then find the Current Version of the Firmware there and download it into my Computer in order to save a copy.
That way if there are any issues with the New Firmware, which has been rare for me, you'll always have a copy of a previous version that worked for you until the bugs are worked out of the new one as is the case right now with the V1.0.9.88_10.2.88 Firmware. This is the first real issue I've had with a Firmware Upgrade.
Hope that helps and Good Luck!!
- Great advice. Thank you.
