ov10mech's avatar
Mar 30, 2019
R7000 5ghz not stable
Running latest firmware V1.0.9.64_10.2.64 -   Multiple devices connected to the 5GHZ side are very unstable.   If you do a constant ping to the router you can see the dropped packets as shown in attachment   2.4ghz is fine but I need the speed of 5.  I have tried messing with the 5ghz channels with no luck.  This is in a single family home so neightbors are not too close.  Anyone else have this issue and anything I can try.  I need to try another vendor if I cant fix this.  WPA2-PSK [AES] if that matters.  Also did complete factory reset recently.
