mtnbykmyk's avatar
mtnbykmyk
Follower
Jul 01, 2026
R7000 AC1900 - AP mode does not connect to primary router with WIFI
I want to use my old R7000 to extend my wifi coverage in my house. I have a new primary router provided by my internet service company. The new router is a Calix GS4220E  EXOS 25.1.0 and has been working well for several months.
I have configured the R7000 for AP mode successfully using an ethernet cable connection to the router. What I want is to connect the R7000 to the router via WIFI.  Is this supported in AP mode?
    No, it is not an option for you.  You'll need to purchase a wifi extender.
    Alternatively, the GS4220E is a mesh router, so you could add another Calix element.  You could contact your ISP for that.  If you want to try adding your own, you could add a second GS4220E, or a GM1028 (Per google, so worth double-checking).  Both are available on ebay (mostly used).
  • StephenB's avatar
  • The R7000 has a "Repeater" mode which is, effectively, an extender.
    • StephenB's avatar
      I forgot it had that mode (most newer Netgear routers do not).
