JMatsCA's avatar
JMatsCA
Initiate
Feb 18, 2019
R7000 AC1900 5Ghz intermittent connection failures
Purchased R7000/AC1900 in April 2018 so it's been about 10 months (currently mid-Feb 2019).
About 3 months ago (mid-Nov 2018), I started noticing that the 5GHz connection occasionally drops.  The SSID for for 5GHz is still visible (I have unique SSIDs for 2.4GHz and 5GHz) and if I try to re-connect from a PC, I get an error message that the passcode is incorrect.  I can still connect on 2.4GHz and throughput is fine.
When I look at the dashboard, it reports no issues and even shows the 5GHz devices as still being conected.
If I wait a while (several minutes to an hour), it can restore.  Rebooting seems to fix the problem, but I have an occasion when it didn't work.
I reset the router to factory defaults and updated all the settings by hand (as opposed to using a backup config).  Disconnects still happen.  I updated to the latest firmware (1.0.9.64) and reset to factory defaults still happens.  The only thing I haven't done is revert the firmware to .34 or .32.  Thinking about doing that, but should I have a reasonable belief that it will help?  And if I do, will I be opening myself to any critical security issues that have since been patched.
I would like like to try and get to some kind of resolution soon as I believe the hardware is still covered.
  • Your troubles started just as they should, namely once you updated to .60. Revert to FW .42, and they will go away. Both .60 and .64 are bad.
    • JMatsCA's avatar
      JMatsCA
      Initiate
      Thanks.  I will give .42 a shot and keep an eye on it.  Will update with results.
