ConsumerOfWater
Jun 15, 2025Initiate
R7000 AC1900 Factory Reset Itself After Power Outage
Our AC1900 has completely reset itself after a power outage last night. Auto updates is disabled but I have kept it up to date manually. Current version is V1.0.12.216_10.2.122 The router is ...
Jun 16, 2025Guru - Experienced User
After FW was updated, had you factory reset the router and setup from scratch then after all was setup on the router, save off a backup configuration to file for safe keeping?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
- ConsumerOfWaterJun 16, 2025Initiate
The firmware hasn’t been updated recently. Unless it was automatic somehow.
when it was updated, I did not set it up from scratch, it has been running issue free for several months until yesterday. I have made a backup now to help get us back up quicker.
I am unable to get the modem information for a while. I believe the cable is cat 6 although I don’t see why the cable would cause a factory reset.
