ConsumerOfWater
Jun 15, 2025Initiate
R7000 AC1900 Factory Reset Itself After Power Outage
Our AC1900 has completely reset itself after a power outage last night. Auto updates is disabled but I have kept it up to date manually. Current version is V1.0.12.216_10.2.122 The router is ...
Jun 16, 2025Guru - Experienced User
After FW was updated, had you factory reset the router and setup from scratch then after all was setup on the router, save off a backup configuration to file for safe keeping?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
ConsumerOfWater
Jun 16, 2025Initiate
The firmware hasn’t been updated recently. Unless it was automatic somehow.
when it was updated, I did not set it up from scratch, it has been running issue free for several months until yesterday. I have made a backup now to help get us back up quicker.
I am unable to get the modem information for a while. I believe the cable is cat 6 although I don’t see why the cable would cause a factory reset.
