3arc
Oct 12, 2019Aspirant
R7000 ac1900 has amber light after a firmware update on the netgear nighthawk app
I need help with the tftp method when you need to count 10 flashing led before entering.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
And go out into Google/Bing and find a video that takes you though the process.
By the way, you will gain nothing by starting multiple discussions of the same problem:
Re: R7000 AC1900 Bling power light after failed ... - Page 3 - NETGEAR Communities
Re: R7000 power Led stays orange when turned on af... - NETGEAR Communities
- 3arcAspirant
Michael what would be the safest easy way to update my router to the newest firmware with windows HP i am no longer going to do it on the nighthawk app or any way not that's not a wired connection btw sorry for the trouble
Check the manual for your device and read the bit about manual updates for firmware.
And read this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
