omoeller
Aug 18, 2015Guide
R7000 and bandwidth control
I am using my R7000 behind a DSL modem as LAN and WiFi router and since a couple of weeks I am recognising an odd behaviour - when one of the other clients connected to the R7000 is starting a download, all other connected clients lose network access - e.g. company connection via VPN, Lync. etc.
This is surely very disruptive when trying to work in home office scenario - just wondering what options I have to manage bandwidth consumption. Is the only way via QoS or is there other options? Already did multiple resets, tried different FW and am now back to the latest stock FW.
Any suggestions are more than welcome - Thanks!
- On an asymmetrical link, where the upload rate is a fraction of the download rate it’s possible to choke the network with upload data. So for example with a large TCP download where packets are acknowledged by the receiving computer then there can be a corresponding high upload of data, and if the upload rate limit is significantly lower that the download rate limit then the Internet connection can grind to a halt. The first few paragraphs of this .pdf might explain better than I can; http://www.sigcomm.org/sites/default/files/ccr/papers/2012/January/2096149-2096158.pdf
- Babylon5NETGEAR Employee RetiredIs your DSL modem also a modem/router combo, and if so is it set to Bridged Mode? Can you say what kind of download causes the issue or is it any type of download?
- omoellerGuide
I am using a AVM Fritzbox 7390 as DSL Modem - this is as modem/router combo and I need to check if it is set to Bridge mode - With regards to the type of download I think it does not really matter - I experienced this in all file download scenarios as well as streaming.
- Babylon5NETGEAR Employee RetiredIf you continue to have issues and you find that your modem is not in Bridged Mode, you might want to consider setting the R7000 to AP mode and leave the modem as currently set. Even if you don’t intend to continue in that setup, it might help in diagnosing the issue.
I assume you tried the R7000 in AP mode while the modem was in router mode?
It’s a bit odd that one client can eat up all the available bandwidth? Can you tell me what rat the client machine is downloading at when the problem occurs please, and what rate you ISP connection provides for both upload and download?
- omoellerGuide
Yes - I did use AP mode while modem was in router mode
I have a suspicion - all wired clients now run on Gigabit LAN up to Modem - my DSL bandwidth is max. 16Mbit - as a result maybe 1 client can eat up all available bandwidth. During a regular download (e.g. 700MB ISO image file) I saw the client eating up full bandwidth on the modem. The odd this is after taking LAN down to max. 100Mbit instead of GigaBit all looks to be ok again again.
- Babylon5NETGEAR Employee RetiredOn an asymmetrical link, where the upload rate is a fraction of the download rate it’s possible to choke the network with upload data. So for example with a large TCP download where packets are acknowledged by the receiving computer then there can be a corresponding high upload of data, and if the upload rate limit is significantly lower that the download rate limit then the Internet connection can grind to a halt. The first few paragraphs of this .pdf might explain better than I can; http://www.sigcomm.org/sites/default/files/ccr/papers/2012/January/2096149-2096158.pdf
