pneumoman
Nov 26, 2022Aspirant
R7000 as a secondary router
My ISP supplied me with a new Access Point that has a built in router/wireless access point. This newer router is a little bit faster, but not as fully featured, does not have a things like USB supp...
- Nov 26, 2022
Do you actually put the R7000 into AP mode?
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
michaelkenward
Nov 26, 2022Guru - Experienced User
Make and model?
So I've hooked up my R7000 with wireless off and DHCP off.
Depending on the answer to the first question, you might like to put the R7000 in to AP mode.
Thoughts?
Tell us what you want to achieve and someone might have other thoughts.
The main options are to put this unnamed "new Access Point", which may or may not be an access point as most people understand it – modem/router is more likely – into bridge (modem only) mode, or to use the R7000 as a genuine access point.
