  • > Is there somthing else I need to do to get to the one I need to???
       Configuring an R7000 WAP will give it a new LAN IP address.  By
    default ("Get dynamically from existing router"), it'll get that new
    address from (the DHCP server in) your main router (C7000).  Hence, an
    an "Attached Devices" report from your main router should tell you what
    the new address of your R7000-as-WAP is.  Point your web browser at that
    IP address.
       It might improve convenience if you reserve a (memorable) LAN IP
    address on the main router for the R7000-as-WAP. (Then restart.)  Look
    for "Address Reservation" in the main-router User Manual.
    • Tmarkreis's avatar
      Tmarkreis
      so.... when I run the ethernet wire from the C7000 to the "yellow" connection on the R7000, it does show up on my list of devices, but if I plug that url address into the search bar I get a "failed to open page" message.  If I plug the wire into any of the other LAN ports, like the above tutorial shows, it doesn't show up in the attached devices list.
      • antinode's avatar
        antinode
        Guru
        > [...] if I plug that url address into the search bar I get a "failed
        > to open page" message. [...]
           What was the actual URL?  Modern browsers tend to favor
        "https://<whatever>" over "http://<whatever>", but only
        "http://<whatever>" will work in this situation.
        > [...] If I plug the wire into any of the other LAN ports, like the
           I'd expect that.  Apparently, the R7000-as-WAP sends its DHCP request
        out the WAN/Internet port, not any of the LAN ports.  That KB article is
        pretty vague about the wiring.  (A yellow cable and a yellow port are
        different things.)  That's why we read the User Manual.
