mohammad_haq
Mar 02, 2019Aspirant
R7000 as repeater with R7000p
I Have a R7000 router. I recently bought another R7000P. Is it possible to use the R7000 as a repeator without any LAN calble? If it must need LAN cable do I get any benifit using a short cable and k...
- Mar 02, 2019
Repeater is not an option in the stock firmware of the R7000. You also don't want repeaters since they cut throughput in half due to the constant need to be in contact back and forth with the main router. As for AP, the length of the cable doesn't matter. Using a short cable will give you no benefit. If you need to cover a large area, just pull a long cable
microchip8
Mar 02, 2019Master
antinode
Mar 02, 2019Guru
> [...] Is it possible to use the R7000 as a repeator without any LAN
> calble? [...]
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Set Up a
Wireless Distribution System".
> [...] do I get any benifit using a short cable and keeping them not
> too far from each other?
I don't know what the benefit of such a configuration would be.
