mohammad_haq
Mar 02, 2019Aspirant
R7000 as repeater with R7000p
I Have a R7000 router. I recently bought another R7000P. Is it possible to use the R7000 as a repeator without any LAN calble? If it must need LAN cable do I get any benifit using a short cable and k...
- Mar 02, 2019
Repeater is not an option in the stock firmware of the R7000. You also don't want repeaters since they cut throughput in half due to the constant need to be in contact back and forth with the main router. As for AP, the length of the cable doesn't matter. Using a short cable will give you no benefit. If you need to cover a large area, just pull a long cable
microchip8
Mar 02, 2019Master
mohammad_haq
Mar 03, 2019Aspirant
Thanks. I took the r7000p back to Umart and they took it back charging me 10% since I opened the box :(. I will look for alternatives.
