basehitter10
Aug 16, 2016Initiate
R7000 Block Services not working properly
All,
Looking for suggestions here:
I have reserved IP addresses for all devices that connect to my router. One particular range (.10 - .16, not that it matters) were set up on a Block Services schedule last night from midnight to 6am.
Block Services ALL, all ports, per schedule - the setting were correct.
At 6am this morning, none of the devices in the IP range could reconnect to the network and I have no idea why.
Any ideas from other users? All input very much appreciated!
Just as mysteriously, the Srvices Blocking started working as advertised the next night. There was no router reboot that I am aware of. Strange.
- storm1985Prodigy
if you disconnect then reconnect to the network will it work?
if you reboot the router will it work as well?
- basehitter10Initiate
