Switch5439
Jan 10, 2017Aspirant
R7000 buffering
Trying to get router to work with IPTV, I use an Android device with the Kodi platform with the Lollipop software on 2 boxes and the Krypton on a third. My problem is I keep getting buffering on IPTV...
- Jan 10, 2017
OP, try rolling back to the previous 1.0.7.2 drivers to see if that fixes your problem. I had so many issues with 1.0.7.6 in regards to WIFI performance that I had to find out via roll back. Sure enough, buffering and disconnect issues went away.
xealo
Switch5439
Jan 11, 2017Aspirant
Thanks I will try that, tried turning off WMM on both 2.4 and 5 G and that seems to help some but I will try the firmware roll back you suggested. Once I download that new firmware do I need to turn on QoS like I have on this version and disable WMM on both 2.4 and 5 G ?
