Switch5439
Jan 10, 2017Aspirant
R7000 buffering
Trying to get router to work with IPTV, I use an Android device with the Kodi platform with the Lollipop software on 2 boxes and the Krypton on a third. My problem is I keep getting buffering on IPTV...
- Jan 10, 2017
OP, try rolling back to the previous 1.0.7.2 drivers to see if that fixes your problem. I had so many issues with 1.0.7.6 in regards to WIFI performance that I had to find out via roll back. Sure enough, buffering and disconnect issues went away.
OmarDeen
Jan 13, 2017Aspirant
Thanks Todd ! I will check it out
Omar
Omar
