dman97's avatar
dman97
Tutor
Dec 25, 2018
R7000 Cannot get to settings from Wired Connection
I  cannot get to the settings on my R7000 router through a wired connection.  I can from a wireless connection.  If I try routerlogin.net I get a screen that says "You are not connected to your Route...
  • dman97's avatar
    dman97
    Dec 25, 2018
    I am embarrassed to say I solved the problem. I still had the wired desktop connected to the att RG. I moved the cable to the R7000 and everything is working as it should now. Thank you again for you input.
