ooeemusic
Jan 30, 2021Aspirant
R7000 can't access setting after setting up VPN
I set up thr R7000 last night because I recently started using express VPN. I followed the directions to set up the router and then the directions to set the VPN up. I now only have access to some of ...
ooeemusic
Directions = the directions the app gives you to set up the router and the directions express VPN gives you to set up the VPN on the router.
antinode
Jan 30, 2021Guru
"the app"? But, in any case, if you install non-Netgear firmware on
your Netgear router, then many things might change.
> [...] the directions express VPN gives you to set up the VPN on the
> router.
Thanks for the helpful link. But, in any case, if you have problems
when using third-party firmware, then you might best ask the third
party about them.
