AkivaM
May 02, 2016Aspirant
R7000 Date/Time is Wrong wrong wrong, old firmware, new firmware
Nighthawk R7000 Firmware 1.0.4.30 Configuration - DNS addresses are fixed as the OpenDNS servers, 208.67.222.222 - 208.67.220.220 My time has been stuck at January, 2003 with the start t...
- May 08, 2016
Yes, the modem is displaying the right time, as is a check connection to netgear time service.
Fortunately an admin here sent me to support, who sent me firmware V1.0.5.49_20151231_ntp
and that fixed it.
VE6CGX
May 02, 2016Master
Tried your ISP DNS?
AkivaM
I didn't set the DNS, the router did when I enabled Parental Controls. If I try to change it now, it tells me that I must "The DNS Server changes will not take effect because of Parental Controls. Disable Parental Controls if you wish to set DNS."
Naturally I don't want to lose Parental Controls, it's the main reason I purchased the R7000 (that it uses OpenDNS for parental control) instead of the Asus competition.
Since, however, I showed in my message above that I am able to access the netgear time site, DNS blockage would not seem to be the issue.
- storm1985May 02, 2016Prodigy
What country, ISP and modem?
- AkivaMMay 03, 2016Aspirant
Israel, Bezeq International, using a TP-Link W9970 VDSL/ADSL2+ router with modem (though not using it's router functions with wifi disabled, beyond a pass through to the R7000)
- VE6CGXMay 02, 2016Master
Default DNS comes when you connect to ISP. Could you remember the very first time you started using the router without parental control did you have same problem? Most routers are synchronizing time to NTP time server. You have to make sure the DNS parental control uses is not the problem.
I came across an older thread about this issue. Looks like old, I mean real old firmware upto x.y.z.38 does not show this problem.
I see these firmwares available on a search...what do you recommend trying?
So I tried disabling Parental Controls, didn't help.
Then I tried setting DNS to fixed Google DNS (8.8.8.8), didn't help.
