AkivaM
May 02, 2016Aspirant
R7000 Date/Time is Wrong wrong wrong, old firmware, new firmware
Nighthawk R7000 Firmware 1.0.4.30 Configuration - DNS addresses are fixed as the OpenDNS servers, 208.67.222.222 - 208.67.220.220 My time has been stuck at January, 2003 with the start t...
- May 08, 2016
Yes, the modem is displaying the right time, as is a check connection to netgear time service.
Fortunately an admin here sent me to support, who sent me firmware V1.0.5.49_20151231_ntp
and that fixed it.
AkivaM
I didn't set the DNS, the router did when I enabled Parental Controls. If I try to change it now, it tells me that I must "The DNS Server changes will not take effect because of Parental Controls. Disable Parental Controls if you wish to set DNS."
Naturally I don't want to lose Parental Controls, it's the main reason I purchased the R7000 (that it uses OpenDNS for parental control) instead of the Asus competition.
Since, however, I showed in my message above that I am able to access the netgear time site, DNS blockage would not seem to be the issue.
storm1985
May 02, 2016Prodigy
What country, ISP and modem?
