windsurfer51's avatar
windsurfer51
R7000 disconnect
I have a R7000  with firmware V1.0.9.88_10.2.88 and no new update is available.
It appears that the router is occasionally disconnecting from the internet on wireless and wired. I thought it would be my  but i have a new one and i still have the problem, this appears to be happening about 20 times a day.
I was wondering if there is a way for me to see in the router settings if this is actually happening.
Thank you
1 Reply
  • > I have a R7000 [...]
       So, not this?:
    > Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
    > [...] with firmware V1.0.9.88_10.2.88 and no new update is available.
       Says who?
       Visit http://netgear.com/support , put in your model number, and look
    for Downloads.  (For older versions, under Firmware and Software
    Downloads, look for "View Previous Versions".)  Find the kit(s).
    Download the kit(s) you want.  Read the "Release Notes" file for
    instructions.  (In the User Manual, look for "firmware", and,
    especially, for a topic like "Manually Upload Firmware to the Router".)
    When that fails because of a deficient User Manual, try:
          https://kb.netgear.com/23960
          https://kb.netgear.com/31573
    > It appears that the router is occasionally disconnecting [...]
       "appears"?  LED activity?  Other actual evidence?  As usual, showing
    actual actions (commands) with their actual results (error messages, LED
    indicators, ...) can be more helpful than vague descriptions or
    interpretations.
    > [...] I thought it would be my but i have a new one and i still have
    > the problem, [...]
       "my "?  Modem?  Has it a maker and model number?
       If _what_ is?
    for Documentation.  Get the User Manual (at least).  Read.  Look for the
    LED descriptions and "Troubleshoot".  ADVANCED > ADVANCED Home?
