exerhlp's avatar
exerhlp
R7000: Failed firmware update to 1.0.9.42
Hi all, I’ve been trying to update router firmware from 1.0.9.26 to 1.0.9.42_10.2.44 since it’s out, and just nothing happens. I’ve tried on my computer, also from my phone, I follow all the steps,...
  • antinode's avatar
    Oct 17, 2018
    > [...] I follow all the steps, [...]
       _Which_ "the steps"?
       Visit http://netgear.com/support , put in your model number, and look
    for Downloads.  (For older versions, under Firmware and Software
    Downloads, look for "View Previous Versions".)  Find the kit(s).
    Download the kit(s) you want.  Read the "Release Notes" file for
    instructions.
