bobrfish
Nov 14, 2016Aspirant
R7000 failed
Purchased two years ago at double price for non-Netgear WIFI router. Expected to download streaming content but never actually used it for that purpose. Use consisted of family cell phones and a ta...
- Retired_MemberNov 15, 2016
I would start with manual it has a troubleshooting chapter which explains how to reset to defaults. It seems for whatever reasons Basic task which resolve 99% of problems has been overlooked.
The manual is free of charge. It does require reading it several times to gain a understanding if not familiar with routers.
http://www.downloads.netgear.com/files/GDC/R7000/R7000_UM.pdf
microchip8
Nov 14, 2016Master
Believe it or not, but NG routers are one of the highest quality hardware-wise. This doesn't mean there are no black sheeps, though. If you need to change routers, go with ASUS this time. Far better firmware, though ASUS also has its issues like it runs hotter due to drawing more power. But you won't find better stock firmware than ASUS.
- bobrfishNov 15, 2016Aspirant
I do not have the expertise to evaluate if NG routers are superior to other brands. Reviews suggest NG is a better router. Yet, mine failed and thus my view of NG product is based on my experience. Five days ago, router was working well and my experience at that point in time was NG quality was excellent.
Thanks for advice concerning ASUS.
What steps if any have you tried to correct the problem.
Rebooted Cisco modem. Rebooted R7000.
Cisco modem is OK as ethernet connected to puter is transferring data well above my service level. The issue is in R7000.
Looked at NG website for assistance. Could not find any documentation regarding do this or try this. Instead NG wants $50 to start assisting me.
I checked this forum out to see if anyone else had a similar problem. Found a thread with same problem and expert reply stated router required replacement.
