bobrfish
Nov 14, 2016Aspirant
R7000 failed
Purchased two years ago at double price for non-Netgear WIFI router. Expected to download streaming content but never actually used it for that purpose. Use consisted of family cell phones and a ta...
- Retired_MemberNov 15, 2016
I would start with manual it has a troubleshooting chapter which explains how to reset to defaults. It seems for whatever reasons Basic task which resolve 99% of problems has been overlooked.
The manual is free of charge. It does require reading it several times to gain a understanding if not familiar with routers.
http://www.downloads.netgear.com/files/GDC/R7000/R7000_UM.pdf
bobrfish
Nov 15, 2016Aspirant
Yes I could and did try answering questions by those attempting to help. However, in the 2 hours and 35 minutes between the question and your post suggesting I respond, I was sleeping.
NG provided a set up "genie" and that was used to set up R7000. I do not remember altering or choosing "settings" and am not sure how to restore "factory settings". Also, when I searched NG website I did not see any instructions regarding "resetting" factory settings. I did see NG stating I would need to pay for help with any problem. Maybe I should have ignored that and kept looking for answers there. There was no obvious path to help on NG pages.
Retired_Member
Nov 15, 2016I would start with manual it has a troubleshooting chapter which explains how to reset to defaults. It seems for whatever reasons Basic task which resolve 99% of problems has been overlooked.
- bobrfishNov 16, 2016Aspirant
I lost the physical manual that came with router. I expected to find a manual on NG website. The manual is probably there somewhere but I could not find it.
Thanks for this electronic version. I suspect it will be helpful.
Regarding button on back, I wrongly presumed it was off/on switch. I believe that was tried without success, but I will give it another attempt.
- Retired_MemberNov 16, 2016
it's a recessed micro switch....use a toothpick to press....listen for the click sound
