pdxOTTO
Aug 28, 2015Aspirant
R7000 Fast WiFi, SLOW Wired/LAN -- Need Help
I'm on an R7000 connected to a Motorola 6141 with Comcast. Provisioned for 100mbps+ with Comcast. On wifi 5 ghz, I'm getting 123 mpbs+ speed, however on my LAN connections, the speed tops out at ...
- Aug 30, 2015
WOW -- it was the damned CAT5. Just switched to a CAT6 on on of my computers and voila... from 33 to 125 mbps like that.
Well.... if anyone else has a prob with slow LAN speeds, check your cables and get rid of the CAT5 crap.
AirWaveZ
Aug 28, 2015Guide
That's very interesting....
i can can only think of some compatibility issue with the Ethernet adapter on your computer or the cable...
have you tried different wired computers and do they all have the same issue ?
did you try using a different cable / ports on the router ?
- pdxOTTOAug 30, 2015Aspirant
Same result on different computers with different cables. I think most cables are CAT5. But that shouldn't account for the difference, right? Aren't they able to handle up to 100 mpbs? I'm getting nowhere close to that on my LAN.
