pdxOTTO's avatar
pdxOTTO
R7000 Fast WiFi, SLOW Wired/LAN -- Need Help
I'm on an R7000 connected to a Motorola 6141 with Comcast. Provisioned for 100mbps+ with Comcast.   On wifi 5 ghz, I'm getting 123 mpbs+ speed, however on my LAN connections, the speed tops out at ...
  • pdxOTTO's avatar
    pdxOTTO
    Aug 30, 2015
    WOW -- it was the damned CAT5. Just switched to a CAT6 on on of my computers and voila... from 33 to 125 mbps like that.
    Well.... if anyone else has a prob with slow LAN speeds, check your cables and get rid of the CAT5 crap.
