jgrodrigueza
Jun 22, 2017Aspirant
R7000 firmware 1.0.8.34_1.2.15 and NTP
My router just updated to Firmware 1.0.8.34_1.2.15 and seems like they messed up the NTP that was fixed a few releases back. My router is now stuck on May 8th 2017 every time it starts and the logs ...
- Jul 12, 2017
Sorry for the delay in this response, I was travelling and was not physically with the device. When I came home, I noticed the NTP was synchronizing properly with firmware 1.0.8.34_1.2.15, made several tests and NTP worked all times (so, fixed itself).
Additionally, I made the latest firmware upgrade (V1.0.9.6_1.2.19) and NTP continues to work. Also noticed that this last version of the firmware lets you specify an NTP server in "Advanced -> Security -> Schedule".
jgrodrigueza
An additional issue, all files created or copied to a drived connected to the router will have the timestamp of the router, making file and folder time stamps incorrect.
