AddisonTech
Jan 13, 2016Guide
R7000 Firmware Bug 1.0.6.28
The other night, I flashed the firmware, as the router notified me of an update to version 1.0.6.28_1.1.83. After doing so, my wife's laptop will no longer connect to the home 2.4 GHz network; howev...
- Apr 06, 2016
So far, so good. I just flashed my R7000 and it even kept my modified IP settings, so I don't have to modify those parameters. It appears to "see" the connected devices, and my Samsung printer works on the IP that was assigned. If I notice any glitches, I'll post again. Also, will Arlo be in the final version and off by default?
Thank you.
gorDelpus
Jan 16, 2016Aspirant
Just updated to the 1.0.6.28_1.1.83 firmware. Guest network working fine. Main 2.4 network not working. Can't login. Tried disabling Arlo. No change.
- jsperberJan 27, 2016Aspirant
I have the same problem!
This is my problem also. Anyone knows what to do?
- JamesGLJan 27, 2016NETGEAR Employee Retired
Hi jsperber,
Have you performed a factory reset already on the router after the update? If not, please reset the router and manually reconfigure it.
