AddisonTech
Jan 13, 2016Guide
R7000 Firmware Bug 1.0.6.28
The other night, I flashed the firmware, as the router notified me of an update to version 1.0.6.28_1.1.83. After doing so, my wife's laptop will no longer connect to the home 2.4 GHz network; howev...
- Apr 06, 2016
So far, so good. I just flashed my R7000 and it even kept my modified IP settings, so I don't have to modify those parameters. It appears to "see" the connected devices, and my Samsung printer works on the IP that was assigned. If I notice any glitches, I'll post again. Also, will Arlo be in the final version and off by default?
Thank you.
Retired_Member
Jan 16, 2016When I downgraded to the last firmware release my router has been working fine.
Killhippie
Jan 17, 2016Prodigy
I have been using 1.0.6.28_1.1.83 since it came out, no issues with 2.4Ghz at all. all devices work fine like PS4 My TV, printer etc.
