AddisonTech
Jan 13, 2016Guide
R7000 Firmware Bug 1.0.6.28
The other night, I flashed the firmware, as the router notified me of an update to version 1.0.6.28_1.1.83. After doing so, my wife's laptop will no longer connect to the home 2.4 GHz network; howev...
- Apr 06, 2016
So far, so good. I just flashed my R7000 and it even kept my modified IP settings, so I don't have to modify those parameters. It appears to "see" the connected devices, and my Samsung printer works on the IP that was assigned. If I notice any glitches, I'll post again. Also, will Arlo be in the final version and off by default?
Thank you.
Cognizant1
Feb 01, 2016Tutor
To Netgear. Please offer a separate firmware for people who have ARLO. So the people who don't and don't want to own it have the option
of keeping their network Fresh and speedy. It seems like adding this has only degraded peoples moral and their home network.
Also keeping the processing power that they had as well. I know you can turn it off but the size of the firmware for that added little bit of (insert your own term for
R HO here). Please also fix the problem that people who run Kaspersky security can't access their Admin Panel's and have to disable just to get to it.
Sorry for the rant. Good day to you.
LeKeiser
Feb 02, 2016Luminary
It's really sad that Netgear seems to prefer to stay so quiet and silent while there are so many posts about this router and this firmware. People will start to mistrust Netgear if that continues...
