AddisonTech
Jan 13, 2016Guide
R7000 Firmware Bug 1.0.6.28
The other night, I flashed the firmware, as the router notified me of an update to version 1.0.6.28_1.1.83. After doing so, my wife's laptop will no longer connect to the home 2.4 GHz network; howev...
- Apr 06, 2016
So far, so good. I just flashed my R7000 and it even kept my modified IP settings, so I don't have to modify those parameters. It appears to "see" the connected devices, and my Samsung printer works on the IP that was assigned. If I notice any glitches, I'll post again. Also, will Arlo be in the final version and off by default?
Thank you.
Sicboy041
Feb 09, 2016Aspirant
I'm having the same issue with my recently flashed R7000. Looks like the 2.4Ghz channel is dropping connections and won't seem to work again unless I perform a router reboot. Would appear to be a bug with the latest firmware update: 1.0.6.28_1.1.83. Can someone with Netgear look into this ASAP? Seeing all the other people on here reporting the same issue should warrant a fix or at least a roll back to a previously released version.
- rpoffenFeb 09, 2016Virtuoso
Netgear is aware of the issue and has pulled that release. If a hard reset to factory defaults and manual reconfigure does not help you, then downgrade to 1.0.4.30.
- brazillianguyFeb 26, 2016Aspirant
This is a problem.. Ever since I upgraded to the latest firmware (which it said for security reasons) I CONSTANTLY drop my wireless to all my devices. Can they solve this please....
- mondenathFeb 27, 2016Prodigy
Here you go. Another Beta firmware.
