AddisonTech
Jan 13, 2016Guide
R7000 Firmware Bug 1.0.6.28
The other night, I flashed the firmware, as the router notified me of an update to version 1.0.6.28_1.1.83. After doing so, my wife's laptop will no longer connect to the home 2.4 GHz network; howev...
- Apr 06, 2016
So far, so good. I just flashed my R7000 and it even kept my modified IP settings, so I don't have to modify those parameters. It appears to "see" the connected devices, and my Samsung printer works on the IP that was assigned. If I notice any glitches, I'll post again. Also, will Arlo be in the final version and off by default?
Thank you.
Sicboy041
Feb 09, 2016Aspirant
I'm having the same issue with my recently flashed R7000. Looks like the 2.4Ghz channel is dropping connections and won't seem to work again unless I perform a router reboot. Would appear to be a bug with the latest firmware update: 1.0.6.28_1.1.83. Can someone with Netgear look into this ASAP? Seeing all the other people on here reporting the same issue should warrant a fix or at least a roll back to a previously released version.
rpoffen
Feb 09, 2016Virtuoso
Netgear is aware of the issue and has pulled that release. If a hard reset to factory defaults and manual reconfigure does not help you, then downgrade to 1.0.4.30.
- brazillianguyFeb 26, 2016Aspirant
This is a problem.. Ever since I upgraded to the latest firmware (which it said for security reasons) I CONSTANTLY drop my wireless to all my devices. Can they solve this please....
- mondenathFeb 27, 2016Prodigy
Here you go. Another Beta firmware.
- JoeHansonFeb 27, 2016Tutor
This beta firmware causes a kernel panic and endless reboots in my R7000:
> fileSize = 28954682
.........................................................................................................................................................................................................................................................................................................................................................................................................................................................killall: bftpd: no process killed
killall: smbd: no process killed
killall: nmbd: no process killed
killall: ntfs-3g: no process killedWriting 28954624 bytes to /dev/mtd2.
done.Doing nvram commit by pid 10890 !
Restarting system.
Digital core power voltage set to 1.0V
Decompressing...done
Digital core power voltage set to 1.0VSHMOO VER 1.13
PKID07DC06011801080000000000001A103F01000000
S300001C3
00001270
RDLYW0 00000004RDENW0 00000032
RDQSW0
0000000000111111111122222222223333333333444444444455555555556666
0123456789012345678901234567890123456789012345678901234567890123
00 -----+++++++++++++++++++++++++X++++++++++++++++++++++++---------
01 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------
02 -------+++++++++++++++++++++++X++++++++++++++++++++++-----------
03 -----++++++++++++++++++++++++X++++++++++++++++++++++++----------
04 ---+++++++++++++++++++++++X++++++++++++++++++++++---------------
05 -----+++++++++++++++++++++++++X++++++++++++++++++++++++---------
06 ---+++++++++++++++++++++++X+++++++++++++++++++++++--------------
07 ---------++++++++++++++++++++++++X+++++++++++++++++++++++-------
08 --+++++++++++++++++++++++X+++++++++++++++++++++++---------------
09 ---------++++++++++++++++++++++++X+++++++++++++++++++++++-------
10 ----++++++++++++++++++++++++X++++++++++++++++++++++++-----------
11 ---------++++++++++++++++++++++++X++++++++++++++++++++++++------
12 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------
13 --------+++++++++++++++++++++++X+++++++++++++++++++++++---------
14 ----+++++++++++++++++++++++++X++++++++++++++++++++++++----------
15 ---------++++++++++++++++++++++++X++++++++++++++++++++++++------
PW00000000000111111111122222222223333333333444444444455555555556666
00 ----+++++++++++++++++++++++++X+++++++++++++++++++++++++---------
01 ------++++++++++++++++++++++++++X+++++++++++++++++++++++++------
02 -----++++++++++++++++++++++++X++++++++++++++++++++++++----------
03 ---+++++++++++++++++++++++++X+++++++++++++++++++++++++----------
04 +++++++++++++++++++++++++X++++++++++++++++++++++++--------------
05 ---++++++++++++++++++++++++++X+++++++++++++++++++++++++---------
06 +++++++++++++++++++++++++X++++++++++++++++++++++++--------------
07 -----++++++++++++++++++++++++++X+++++++++++++++++++++++++-------
08 -+++++++++++++++++++++++++X++++++++++++++++++++++++-------------
09 --------+++++++++++++++++++++++++X+++++++++++++++++++++++++-----
10 ---+++++++++++++++++++++++++X++++++++++++++++++++++++-----------
11 --------+++++++++++++++++++++++++X+++++++++++++++++++++++++-----
13 --------++++++++++++++++++++++++X+++++++++++++++++++++++--------
14 ---++++++++++++++++++++++++++X++++++++++++++++++++++++++--------
15 ---------+++++++++++++++++++++++++X+++++++++++++++++++++++++----
NW00000000000111111111122222222223333333333444444444455555555556666
00 ------+++++++++++++++++++++++++X++++++++++++++++++++++++--------
01 --------+++++++++++++++++++++++++X+++++++++++++++++++++++++-----
02 -------++++++++++++++++++++++++X++++++++++++++++++++++++--------
04 --++++++++++++++++++++++++X++++++++++++++++++++++++-------------
05 -----+++++++++++++++++++++++++X+++++++++++++++++++++++++--------
06 ----+++++++++++++++++++++++X++++++++++++++++++++++--------------
07 ---------+++++++++++++++++++++++++X++++++++++++++++++++++++-----
09 --------++++++++++++++++++++++++X++++++++++++++++++++++++-------
15 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------
WRDQW00000000000111111111122222222223333333333444444444455555555556666
00 +++++++++++++++++++++++X++++++++++++++++++++++-------++++++++++-
01 ++++++++++++++++++++++++X+++++++++++++++++++++++-------++++++++-
02 ++++++++++++++++++++++X++++++++++++++++++++++-------+++++++++++-
03 ++++++++++++++++++++++X++++++++++++++++++++++--------++++++++++-
04 ++++++++++++++++++++X++++++++++++++++++++------------++++++++++-
05 +++++++++++++++++++++++X++++++++++++++++++++++------+++++++++++-
06 +++++++++++++++++++++X++++++++++++++++++++---------++++++++++++-
07 +++++++++++++++++++++++X+++++++++++++++++++++++------++++++++++-
08 ++++++++++++++++++++++X++++++++++++++++++++++--------++++++++++-
09 ++++++++++++++++++++++++X+++++++++++++++++++++++---------++++++-
10 +++++++++++++++++++++++X++++++++++++++++++++++-------++++++++++-
11 --+++++++++++++++++++++++X++++++++++++++++++++++----------+++++-
12 +++++++++++++++++++++++X++++++++++++++++++++++------+++++++++++-
13 -+++++++++++++++++++++++X+++++++++++++++++++++++---------++++++-
14 ++++++++++++++++++++++++X+++++++++++++++++++++++-------++++++++-
15 --+++++++++++++++++++++++X++++++++++++++++++++++----------+++++-
WRDMW0 00000022
WRDMW0 00000023
ADDR0000000000111111111122222222223333333333444444444455555555556666
00 ++++++++++++++++++S++++++++++++X++++++++++++++++++++++++++++++++Decompressing...done
CFE for Foxconn Router R7000 version: v1.0.21
Build Date: Wed Aug 7 19:11:17 CST 2013
Init Arena
Init Devs.
Boot up from NAND flash...
Bootcode Boot partition size = 524288(0x80000)
DDR Clock: 800 MHz
Info: DDR frequency set from clkfreq=1000,*800*
et0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.15.1 (r407936)
CPU type 0x0: 1000MHz
Tot mem: 262144 KBytesDevice eth0: hwaddr E4-F4-C6-03-58-36, ipaddr 192.168.1.1, mask 255.255.255.0
gateway not set, nameserver not set
Checking crc...Loader:raw Filesys:raw Dev:nflash0.os File: Options:(null)
Loading: ..... 5405952 bytes read
Entry at 0x00008000
Closing network.
Starting program at 0x00008000
[ 2.040000] console [ttyS0] enabled, bootconsole disabled
[ 2.050000] serial8250.0: ttyS1 at MMIO 0x18000400 (irq = 117) is a 16550
[ 2.060000] brd: module loaded
[ 2.070000] loop: module loaded
[ 2.070000] pflash: found no supported devices
[ 2.080000] bcmsflash: found no supported devices
[ 2.670000] Boot partition size = 524288(0x80000)
[ 2.670000] lookup_nflash_rootfs_offset: offset = 0x200000
[ 2.680000] nflash: squash filesystem with lzma found at block 32
[ 2.680000] Creating 17 MTD partitions on "nflash":
[ 2.690000] 0x000000000000-0x000000080000 : "boot"
[ 2.690000] 0x000000080000-0x000000200000 : "nvram"
[ 2.700000] 0x000000200000-0x000002200000 : "linux"
[ 2.710000] 0x00000041c3d8-0x000002200000 : "rootfs"
[ 2.710000] 0x000002200000-0x000002240000 : "board_data"
[ 2.720000] 0x000002240000-0x000002280000 : "POT1"
[ 2.720000] 0x000002280000-0x0000022c0000 : "POT2"
[ 2.730000] 0x0000022c0000-0x000002340000 : "T_Meter1"
[ 2.740000] 0x000002340000-0x0000023c0000 : "T_Meter2"
[ 2.740000] 0x0000023c0000-0x000002400000 : "ML1"
[ 2.750000] 0x000002400000-0x000002440000 : "ML2"
[ 2.750000] 0x000002440000-0x000002480000 : "ML3"
[ 2.760000] 0x000002480000-0x0000024c0000 : "ML4"
[ 2.760000] 0x0000024c0000-0x000002500000 : "ML5"
[ 2.770000] 0x000002500000-0x000002540000 : "ML6"
[ 2.780000] 0x000002540000-0x000002580000 : "ML7"
[ 2.780000] 0x000002580000-0x0000025c0000 : "QoSRule"
[ 2.790000] PPP generic driver version 2.4.2
[ 2.790000] PPP MPPE Compression module registered
[ 2.800000] NET: Registered protocol family 24
[ 2.800000] PPPoL2TP kernel driver, V0.17
[ 2.810000] tun: Universal TUN/TAP device driver, 1.6
[ 2.810000] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[ 2.820000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.830000] ehci_hcd 0000:00:0b.1: EHCI Host Controller
[ 2.840000] ehci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 1
[ 2.880000] ehci_hcd 0000:00:0b.1: irq 111, io mem 0x18021000
[ 2.900000] ehci_hcd 0000:00:0b.1: USB 0.0 started, EHCI 1.00
[ 2.900000] match id
[ 2.900000] hub 1-0:1.0: USB hub found
[ 2.910000] hub 1-0:1.0: 2 ports detected
[ 2.910000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.920000] ohci_hcd 0000:00:0b.0: OHCI Host Controller
[ 2.920000] ohci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 2
[ 2.930000] ohci_hcd 0000:00:0b.0: irq 111, io mem 0x18022000
[ 3.000000] match id
[ 3.000000] hub 2-0:1.0: USB hub found
[ 3.010000] hub 2-0:1.0: 2 ports detected
[ 3.020000] xhci_hcd 0000:00:0c.0: xHCI Host Controller
[ 3.020000] xhci_hcd 0000:00:0c.0: new USB bus registered, assigned bus number 3
[ 3.030000] xhci_hcd 0000:00:0c.0: irq 112, io mem 0x18023000
[ 3.040000] xhci_hcd 0000:00:0c.0: Failed to enable MSI-X
[ 3.040000] xhci_hcd 0000:00:0c.0: failed to allocate MSI entry
[ 3.050000] usb usb3: No SuperSpeed endpoint companion for config 1 interface 0 altsetting 0 ep 129: using minimum values
[ 3.060000] xHCI xhci_add_endpoint called for root hub
[ 3.070000] xHCI xhci_check_bandwidth called for root hub
[ 3.070000] match id
[ 3.070000] hub 3-0:1.0: USB hub found
[ 3.080000] hub 3-0:1.0: 1 port detected
[ 3.080000] usbcore: registered new interface driver cdc_acm
[ 3.090000] cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
[ 3.100000] usbcore: registered new interface driver usblp
[ 3.100000] csw_retry 100
[ 3.110000] Initializing USB Mass Storage driver...
[ 3.110000] usbcore: registered new interface driver usb-storage
[ 3.120000] USB Mass Storage support registered.
[ 3.120000] usbcore: registered new interface driver usbserial
[ 3.130000] USB Serial support registered for generic
[ 3.130000] match id
[ 3.140000] match id
[ 3.140000] usbcore: registered new interface driver usbserial_generic
[ 3.150000] usbserial: USB Serial Driver core
[ 3.150000] USB Serial support registered for GSM modem (1-port)
[ 3.160000] match id
[ 3.160000] usbcore: registered new interface driver option
[ 3.160000] option: v0.7.2:USB Driver for GSM modems
[ 3.170000] USB Serial support registered for Sierra USB modem
[ 3.170000] usbcore: registered new interface driver sierra
[ 3.180000] sierra: v.1.7.16:USB Driver for Sierra Wireless USB modems
[ 3.190000] u32 classifier
[ 3.190000] Actions configured
[ 3.190000] IPv4 over IPv4 tunneling driver
[ 3.200000] GRE over IPv4 tunneling driver
[ 3.200000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.210000] TCP cubic registered
[ 3.210000] NET: Registered protocol family 10
[ 3.220000] lo: Disabled Privacy Extensions
[ 3.220000] tunl0: Disabled Privacy Extensions
[ 3.230000] IPv6 over IPv4 tunneling driver
[ 3.230000] sit0: Disabled Privacy Extensions
[ 3.240000] ip6tnl0: Disabled Privacy Extensions
[ 3.240000] NET: Registered protocol family 17
[ 3.240000] 802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
[ 3.250000] All bugs added by David S. Miller <[email protected]>
[ 3.270000] Northstar brcmnand NAND Flash Controller driver, Version 0.1 (c) Broadcom Inc. 2012
[ 3.280000] NAND device: Manufacturer ID: 0xc2, Chip ID: 0xf1 (Unknown NAND 128MiB 3,3V 8-bit)
[ 3.290000] Spare area=64 eccbytes 56, ecc bytes located at:
[ 3.300000] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 20 21 22 23 24 25 26 27 28 29 30 31 34 35 36 37 38 39 40 41 42 43 44 45 46 47 50 51 52 53 54 55 56 57 58 59 60 61 62 63
[ 3.310000] Available 7 bytes at (off,len):
[ 3.320000] (1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)
[ 3.320000] Scanning device for bad blocks
[ 3.630000] Options: NO_AUTOINCR,NO_READRDY,
[ 3.640000] Creating 2 MTD partitions on "brcmnand":
[ 3.640000] 0x000002600000-0x000007b00000 : "brcmnand"
[ 3.650000] 0x000007b00000-0x000008000000 : "OpenVPN"
[ 3.660000] SQUASHFS error: Xattrs in filesystem, these will be ignored
[ 3.670000] SQUASHFS error: squashfs_read_data failed to read block 0x1979314
[ 3.670000] SQUASHFS error: Unable to read metadata cache entry [1979314]
[ 3.680000] SQUASHFS error: Unable to read inode 0x3b141a77
[ 3.690000] VFS: Cannot open root device "mtdblock3" or unknown-block(31,3)
[ 3.690000] Please append a correct "root=" boot option; here are the available partitions:
[ 3.700000] 1f00 512 mtdblock0 (driver?)
[ 3.710000] 1f01 1536 mtdblock1 (driver?)
[ 3.710000] 1f02 32768 mtdblock2 (driver?)
[ 3.720000] 1f03 30607 mtdblock3 (driver?)
[ 3.720000] 1f04 256 mtdblock4 (driver?)
[ 3.730000] 1f05 256 mtdblock5 (driver?)
[ 3.730000] 1f06 256 mtdblock6 (driver?)
[ 3.740000] 1f07 512 mtdblock7 (driver?)
[ 3.740000] 1f08 512 mtdblock8 (driver?)
[ 3.750000] 1f09 256 mtdblock9 (driver?)
[ 3.750000] 1f0a 256 mtdblock10 (driver?)
[ 3.760000] 1f0b 256 mtdblock11 (driver?)
[ 3.760000] 1f0c 256 mtdblock12 (driver?)
[ 3.770000] 1f0d 256 mtdblock13 (driver?)
[ 3.770000] 1f0e 256 mtdblock14 (driver?)
[ 3.780000] 1f0f 256 mtdblock15 (driver?)
[ 3.780000] 1f10 256 mtdblock16 (driver?)
[ 3.790000] 1f11 87040 mtdblock17 (driver?)
[ 3.790000] 1f12 5120 mtdblock18 (driver?)
[ 3.800000] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,3)
[ 3.810000] [<c0047250>] (unwind_backtrace+0x0/0xe4) from [<c03d499c>] (panic+0x68/0x194)
[ 3.810000] [<c03d499c>] (panic+0x68/0x194) from [<c0009404>] (mount_block_root+0x238/0x288)
[ 3.820000] [<c0009404>] (mount_block_root+0x238/0x288) from [<c0009700>] (prepare_namespace+0x160/0x1c0)
[ 3.830000] [<c0009700>] (prepare_namespace+0x160/0x1c0) from [<c0009078>] (kernel_init+0x1c8/0x218)
[ 3.840000] [<c0009078>] (kernel_init+0x1c8/0x218) from [<c0041b58>] (kernel_thread_exit+0x0/0x8)
[ 3.850000] CPU1: stopping
[ 3.850000] [<c0047250>] (unwind_backtrace+0x0/0xe4) from [<c00402f0>] (do_IPI+0xfc/0x180)
[ 3.850000] [<c00402f0>] (do_IPI+0xfc/0x180) from [<c04bf8a8>] (__irq_svc+0x48/0xe8)
[ 3.850000] Exception stack(0xcf83df98 to 0xcf83dfe0)
[ 3.850000] df80: c05129a4 00000000
[ 3.850000] dfa0: cf83dfe0 00000000 cf83c000 c050ebc8 c05300a8 c0530220 80000000 413fc090
[ 3.850000] dfc0: 0000001f 00000000 c0563cd8 cf83dfe0 c0041bb0 c0041bb4 60000013 ffffffff
[ 3.850000] [<c04bf8a8>] (__irq_svc+0x48/0xe8) from [<c0041bb4>] (default_idle+0x24/0x28)
[ 3.850000] [<c0041bb4>] (default_idle+0x24/0x28) from [<c0041d1c>] (cpu_idle+0x40/0x94)
[ 3.850000] [<c0041d1c>] (cpu_idle+0x40/0x94) from [<80008138>] (0x80008138)
[ 4.080000] NVRAM LOG 16384 4537 20921
[ 4.240000] Rebooting in 3 seconds..Digital core power voltage set to 1.0V
