AddisonTech
Jan 13, 2016Guide
R7000 Firmware Bug 1.0.6.28
The other night, I flashed the firmware, as the router notified me of an update to version 1.0.6.28_1.1.83. After doing so, my wife's laptop will no longer connect to the home 2.4 GHz network; howev...
- Apr 06, 2016
So far, so good. I just flashed my R7000 and it even kept my modified IP settings, so I don't have to modify those parameters. It appears to "see" the connected devices, and my Samsung printer works on the IP that was assigned. If I notice any glitches, I'll post again. Also, will Arlo be in the final version and off by default?
Thank you.
nhoover
Mar 05, 2016Aspirant
I upgraded from 1.0.4.30 to 1.0.6.28_1.1.83 back in late January. Since that time, I've tried all the settings but my 2.4 main network can't be used by any device. The 2.4Ghz guest network is fine as are both 5Ghz networks.
Finally I got sick of it and downgraded back to 1.0.4.30 and all is well again.
Netgear, this is really disappointing. You are usually much better than this. It's not like it's particularly easy to post here yet there are 5 pages of people with this problem. I wonder how many separate customers with issues each post here represents? I won't be upgrading again anytime soon, that's for sure.
ElaineM
Mar 07, 2016NETGEAR Employee Retired
nhoover We apologize for any inconvenience this may have caused you. Our engineers are aware and the fix is on the works. The firmware will be released soon.
- AddisonTechMar 07, 2016Guide
Will the release automatically invoke the Arlo function, or will there be an option to leave it off without having to drill down to find it? This should be a user choice option for those of us who do not have any Arlo devices.
- ElaineMMar 07, 2016NETGEAR Employee Retired
There will be an option to disable the Arlo function for users who does not have Arlo devices.
- ender2003Mar 07, 2016Tutor
That right there is a big part of the problem. One of the big complaints is that this should be opt-in, not opt-out. Why enable a feature by default when more than half of the user base won't use it or disable it immediately?
- KaptajnenMar 26, 2016Aspirant
ElaineM Has Netgear released the promised firmware fix that you mentioned?
if so, please give me a link to download it.
Thank you
