AddisonTech
Jan 13, 2016Guide
R7000 Firmware Bug 1.0.6.28
The other night, I flashed the firmware, as the router notified me of an update to version 1.0.6.28_1.1.83. After doing so, my wife's laptop will no longer connect to the home 2.4 GHz network; howev...
- Apr 06, 2016
So far, so good. I just flashed my R7000 and it even kept my modified IP settings, so I don't have to modify those parameters. It appears to "see" the connected devices, and my Samsung printer works on the IP that was assigned. If I notice any glitches, I'll post again. Also, will Arlo be in the final version and off by default?
Thank you.
ElaineM
Apr 06, 2016NETGEAR Employee Retired
Can you guys try this new beta FW v1.0.5.60 and report back?
Please let us know if you are still experiencing the 2.4Ghz not working and/on any 2.4Ghz WiFi stability issues.
This beta FW release does not include Arlo integration.
AddisonTech
Apr 06, 2016Guide
Thank you.
