Sezro626's avatar
May 26, 2021
R7000 Firmware Update?
I have been having WiFi issues daily. It cuts out sometimes multiple times a day. Is there an easy way to update the firmware? I'm currently using v1.0.9.88_10.2.88 I would like to restore it to a previous version. I am trying to avoid a hard reset because it is a pain to reset up evertyhting especially Ring.
Can I download a previously version and upload to the GUI?
  • plemans's avatar
    You can download the older firmware and install it if you'd prefer. You can even use the newer versions (the one you're on isn't the latest).
    https://www.netgear.com/support/product/r7000.aspx
    I'd still recommend a factory reset with the R7000 with firmware changes just because resetting has been shown to give the r7000 the best results. Especially when going from the .88 version to an older version. (because it got netgear armor added)
