fstarne
May 24, 2016Aspirant
R7000 firmware version 1.0.5.64_1.1.88 released today
| New Firmware Version | 1.0.5.64_1.1.88 |
| Release Notes | |
| 1. [New Feature] Supports Smart Connect. | |
| 2. [New Feature] Supports the Kwilt app, which can be used to view photos stored on the R7000. | |
| 3. [New Feature] Supports NETGEAR Downloader (Beta). | |
| 4. [New Feature] Supports VPN service support for iOS and Android mobile clients. | |
| 5. [New Feature] Sends log reports via SSL email. | |
| 6. [New Feature] Supports IGMP proxy for British Telecom. | |
| 7. [New Feature] Supports Transmit Power Control. | |
| 8. [Enhancement] Improves port forwarding by allowing fixed and range ports to be added to one rule. | |
| 9. [Enhancement] Improves the QoS GUI. | |
| 10. [Enhancement] Supports IP-MAC binding for the PR region. | |
| 11. [Enhancement] Supports Super WiFi for the PR region. | |
| 12. [Enhancement] Supports DNS 3322 for the PR region. | |
| 13. [Enhancement] Supports Russian WAN installation and IPTV port support | |
| 14. [Bug Fix] ReadyShare Printer Vulnerability issue. | |
| 15. [Bug Fix] Fix Web GUI missing genie app download page when accessing from Windows 10 Edge browser. | |
| 16. [Bug Fix] iTunes 12.1 support. |
DwayneW Yes, it should fix it.
- tomdzAspirant
I've noticed that GUI Language Versions reads V1.0.6.28_2.1.38.2 after upgrading to this firmware, is this expected? Firmware Version gives the correct number.
Does this firmware have time sync fix? I am running V1.0.5.49_20151208_timesync firmware. Want to make sure before upgrading.
- orientboy2Aspirant
When you reset after a firmware upgrade do you need to input all the previouse reserved IP addresses?
- LeKeiserLuminary
Hello,
A reset restore the modem to the first state it was when you took it out of the box. So you have to reconfigure it the way you want it to be after.
- ablattApprentice
So is the fact that not many people are posting an indication that this firmware is working well? I still haven't updated from 1.0.4.30.
How is the range on 2.4 and 5 GHz compared to 1.0.4.30?
Also, after upgrading is resetting in the GUI OK, or should I use the reset button?
- jetspeedzLuminary
I'm curious about this as well. I avoided the whole last round of updates and stuck with 4.30 and glad I did. I don't want to update until i know it is problem free so hoping for some more feedback. The majority of the changes don't really appear to provide any signal improvement features.
- IrvSpMaster
Sort of a catch-22 here. Even if you see 'bad' reports you don't know why? Did they install over a newer V1.0.5 or .6 beta that was removed/recalled and NOT reset and re-enter settings? Did they have other problems that might not bother your (DMZ usage, port forwarding, etc,). Do you like 'living on the bleeding edge' and willing to try something else to see if it is better? You'll never really know the percents of reports vs. content users... very few that have it working well will report such.
Then there is the old addage, "if it ain't broke, don't fix it".
Unless one has made significant repeatable measurements of speed or power levels are different ranges on the SSID bands the answer you want is going to be hard to find, and even if they did, it would be in their environment only.
- gumicsirkeAspirant
Hi,
After upgrading to R7000-V1.0.5.64_1.1.88 from R7000-V1.0.4.30_1.1.67 two bugs appeared till now:
- LAN setup page: Starting/Ending IP Address cannot be changed, it reverts back to default after apply/apply+restart every time.
- VPN Service: Cannot enable service or change ports, because error popup appears saying something like "not allowed port number, port number must be 65536 or less".
How about a new FW update that includes Arlo support?
I've had to use 1.0.6.40 to allow Arlo to function. This is a very imporatnt feature for me.
- bigdpsAspirant
Hopefully you guys can help me.
I updated to the latest 1.0.5.64 firmware and ever since, I have had nothing but connectivity problems.
I used to have 1.06.28 and didn't have any problems.
This is what is happenning: Every so many minutes, all my wire connected computers lose access to the internet. I can see everything on my lan but nothing outside. Same goes for wireles at 2.4g. However, 5g works no problem. When I look at the GUI, it tells me I have internet access which is true but it doesn't share with the connected PC or 2.4.
I have updated the firmware, reset it and start from scratch, setting it up again. No matter what I try, it doesn't work.
I went back to 1.06.28 and the problem is still there although it took about 18 hours before losing internet from inside the lan.
Surely I can't be the only one with this problem?
- RMinNJLuminaryYou went back to your old firmware and you still had the problem albeit less often?
But 5g has Internet 100% of the time for both firmware versions?
It sounds like a hardware problem with the router then...- bigdpsAspirant
What's even weird is that when I went back a firmware, the GUI from the latest firmware was still present. That to me was an indication something was not kosher.
I gave up and bought a new one to see if it will do the same problem. Of course the firmware that was on that one was way older so I installed the 1.4.30 since I need VLAN access which the old version didn't have.
The old router hadn't connected to get my email since 2 in the morning.What's weird is that Skype could connect, certain websites too but not google. There are so many variables in this situation that I didn't know where to start. So hopefully, a new router will let me know where the problem is.
Pretty sad I had bought the other back in April of 2015 and if it is in fact the harware, that is pretty pathetic.
- Has anyone heard of any issues with port forwarding on 1.0.6.40?
I entered same rules I had from previous 1.0.6.28 version but can't get it to work correctly on this fw. - Fulgore206AspirantMany issues, WiFi speeds slows down after seconds, WiFi signal is bad, download speed is about 10mb/s slower, GUI version is wrong, security bug , admin is still logged in after reboot router, QoS settings menu is terrible slow, WiFi range is worse than previous 3 firmwares , even I do everything manually, reset router ,flash firmware , reset router, all setting I put back manually, also bug for me, I use ppoe and password is plain text, nothing is hidden , for a 200 dollar I expected more....
- Fulgore206AspirantAlmost forget, since last update firmware WiFi cause an high pitch sound the moment a download start...LAN PC says not connected even I have internet and a pop-up appears with you need to login in browser to configure, also it send wake up signals to my WD TV live media player, I had it now 2 times when I wake that my TV is on and the WD TV device...
No doubt about it, Fulgore, you've got some serious issues there.
All I can tell you is that my R7000 is humming along at top speed, and as stable as granite since updating to firmware version 1.0.5.64_1.1.88
Good luck!
AntonK
