Phil-H
Mar 15, 2016Aspirant
R7000 Guest Network - how to set up?
I followed the instructions in: http://kb.netgear.com/app/answers/detail/a_id/24097/~/how-do-i-set-up-a-guest-network-on-my-nighthawk-router But, none of my client devices will connect. I hav...
- Mar 23, 2016
Thanks. Turns out it needed a power off, with a long rest, then a power up, for the Guest Network to allow connections. Maybe its brains were scrambled.
Phil-H
Sorry I was not clear - my problem is that no one can connect with the Guest Network!!
ElaineM
Mar 21, 2016NETGEAR Employee Retired
What's the device that's trying to connect to the Guest Network?
Is this working before?
Try factory reset and see if that will help.
- Phil-HMar 23, 2016Aspirant
