XMAN512
Jul 05, 2021Aspirant
R7000 Intermitting Dropping WIFI Daily
My Netgear Nighthawk R7000 continues to drop signal throughout the day. Intermitting. I have read other Netgear Community news feeds. It advises to downgrading to version 1.0.9.42. Hardwired connecti...
antinode
Jul 05, 2021Guru
> Model: R7000|AC1900 Smart WIFI Router
Firmware version? Connected to what?
> My Netgear Nighthawk R7000 continues to drop signal [...]
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for the
LED descriptions and "Troubleshoot". Further reading might not hurt,
either.
What, exactly, does "drop signal" mean to you? _Which_ "signal"? Is
the connection between your ISP and the R7000 lost? Or between the
R7000 and your (unspecified, connected someway) computer/device? Or
what, exactly?
> [...] I have read other Netgear Community news feeds. [...]
Thanks for the helpful links.
> [...] It advises to downgrading to version 1.0.9.42. [...]
"It"? Which version(s) have you tried?
https://community.netgear.com/t5/x/x/m-p/2069376#M186506
> [...] Can someone please confirm if these are the correct steps to
> solution.
Judging a "solution" can be unreliable without a useful problem
description. Why not run the experiment?
