fhomess's avatar
fhomess
R7000 Internet Connectivity Issue
I'm suddenly having issues with my Nighthawk R7000.
I have a work laptop that is connected to the WiFi on the router and seems to be working fine.  It's actually what I'm posting this message from.
However, I can't get any other devices to have internet connection.
The Home page of the R7000 admin portal says Internet is "Not Connected".  The R7000 has a wired connection to my CenturyLink (CL) router.  I have the WiFi antenna on the CL router disabled.
I tried a factory reset on the router and set up the same WiFi settings again and that didn't help.  I've also power cycled the CL router.
Firmware on the R7000 is v1.0.11.126_10.2.112.  It's set to auto update.  When I try to run a manual check for an update, it says it can't connect to the internet.
The thing that's really got me is that the work laptop connects just fine.
