chrisr1
Nov 28, 2016Initiate
R7000 keeps dropping wifi connection
Hi, I have a Netgear R7000 router which I purchased 4 months ago. Recently it has been dropping the wifi connection intermittantly which seems to be getting worse, which is really annoying when try...
- May 03, 2017
Hi Garyr51,
Try to reset the router to factory default and reconfigure it manually. Change the channel of both 2.4Ghz and 5Ghz.
Hi PChell,
If your device is D7000, I would suggest posting it under DSL modem.
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
smithdal
Same exact problem and it just started a few days ago on previous version so I download and install the Firmware Version
V1.0.7.2_1.1.93 but problem still exists. I have isolated the entire network back to the R7000 itself. I am completely frustrated with this issue that seems to randomly drop the connection over and over again within seconds of connecting. I have reset to factory settings and reconfigured only to have the same exact issue. Oh and I have had my R7000 running for 2 years now and with no issues at all. I was completely satisfied with this router and even refered others to it. I am very suprised to hear of others having the same issue with differnt model.
- JamesGLDec 01, 2016NETGEAR Employee Retired
Hi All,
1. Does disconnection happens on both 2.4Ghz and 5Ghz?
2. When internet is down, are your devices still connected to the wireless network or not?
3. Is the wired connection stable?
JamesGL
Community Team- chrisr1Dec 01, 2016Initiate
Hi James,
The disconnection happens on both 2.4GHz and 5GHz networks. iOs drops the connection after a few seconds, whilst Windows still shows the connection in the task bar but is unable to reach the router or any other network locations or the internet.The wired connection remains stable.
Thanks,
Chris
Hi chrisr1,
Try to reset the router to factory default and manually reconfigure. Test the connection. If still the same, try reloading the previous firmware and reset.
http://kb.netgear.com/app/answers/detail/a_id/30766
JamesGL
Community Team
- PrimeNumberFeb 01, 2017Guide
When it goes down, it usually happens on both bands. With an analyzer running, I did see the 5Ghz go down, but the 2.4Ghz stay up, but it only happened like that one time out of 50. The connections may or may not drop. It depends on how long the signal is down. It can be a split second or several seconds.
I do not have direct evidence of the wired connection going down, but I have noticed that my Xbox (wired) will time out now and then. I have been playing Battlefield 1 a lot recently, so this may be the Dice servers kicking me as opposed to my router failing.
