chrisr1
Nov 28, 2016Initiate
R7000 keeps dropping wifi connection
Hi, I have a Netgear R7000 router which I purchased 4 months ago. Recently it has been dropping the wifi connection intermittantly which seems to be getting worse, which is really annoying when try...
- May 03, 2017
Hi Garyr51,
Try to reset the router to factory default and reconfigure it manually. Change the channel of both 2.4Ghz and 5Ghz.
Hi PChell,
If your device is D7000, I would suggest posting it under DSL modem.
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
JamesGL
Dec 01, 2016NETGEAR Employee Retired
Hi All,
1. Does disconnection happens on both 2.4Ghz and 5Ghz?
2. When internet is down, are your devices still connected to the wireless network or not?
3. Is the wired connection stable?
JamesGL
Community Team
chrisr1
Dec 01, 2016Initiate
Hi James,
The disconnection happens on both 2.4GHz and 5GHz networks. iOs drops the connection after a few seconds, whilst Windows still shows the connection in the task bar but is unable to reach the router or any other network locations or the internet.
The wired connection remains stable.
Thanks,
Chris
- JamesGLDec 01, 2016NETGEAR Employee Retired
Hi chrisr1,
Try to reset the router to factory default and manually reconfigure. Test the connection. If still the same, try reloading the previous firmware and reset.
http://kb.netgear.com/app/answers/detail/a_id/30766
JamesGL
Community Team
