chrisr1
Nov 28, 2016Initiate
R7000 keeps dropping wifi connection
Hi, I have a Netgear R7000 router which I purchased 4 months ago. Recently it has been dropping the wifi connection intermittantly which seems to be getting worse, which is really annoying when try...
- May 03, 2017
Hi Garyr51,
Try to reset the router to factory default and reconfigure it manually. Change the channel of both 2.4Ghz and 5Ghz.
Hi PChell,
If your device is D7000, I would suggest posting it under DSL modem.
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
bookmom31
Feb 01, 2017Tutor
I'm having the same problems. Started two days ago and can't seem to find a solid solution.
