chrisr1
Nov 28, 2016Initiate
R7000 keeps dropping wifi connection
Hi, I have a Netgear R7000 router which I purchased 4 months ago. Recently it has been dropping the wifi connection intermittantly which seems to be getting worse, which is really annoying when try...
- May 03, 2017
Hi Garyr51,
Try to reset the router to factory default and reconfigure it manually. Change the channel of both 2.4Ghz and 5Ghz.
Hi PChell,
If your device is D7000, I would suggest posting it under DSL modem.
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
sjavanovich
Mar 14, 2017Initiate
Having the same problems.. thought it was the crappy Netgear USB Wifi AC1200 (which has also had tons of problems).. replaced with a Linksys usb. works better but still having drops. I think it is the $200+ R7000...... Tried all the ideas.. reset, hardware reset, channels, my provider looked at it twice..
Netgear.... come up with a solution or should i just go with all linksys?
JamesGL
Mar 16, 2017NETGEAR Employee Retired
Hi sjavanovich,
1. What is the firmware version of the router?
2. How many wireless devices connected? Are all of them having the same problem?
3. Does it happen on 2.4Ghz or 5Ghz or both connection?
- JamesGLMar 19, 2017NETGEAR Employee Retired
Hi sjavanovich,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- Garyr51Mar 25, 2017Tutor
I am having the same problem with my 2 month old R7000. Every few days, the wifi drops on all my devices. Both 2.4 and 5ghz. The only thing that seems to correct it, is a router reboot. I did a chat with a support rep, (case number 28222817) he recommended changing the channels to 11 and 153. (2.4 and 5ghz). I did this two days ago, had the same issue this morning. I am seeing a lot of R7000 customers online with the same issue. Is this a faulty router??
- PrimeNumberMar 27, 2017Guide
So, I ended up resetting the router by holding the reset button for 10 seconds. Before you do this, you may want to get your router up to the latest firmware. Resetting the router removed all settings and put it back to factory default, but left it at the latest firmware level. I went in an manually set everything up in the router again. I did NOT restore from a backup.
The router has been working fine for the past couple months since I have done this. I speculate that a cache or something was cleared in this process as all the settings I had before are now programmed in to the router. The only difference is that I get a continuous, strong WiFi signl all over the house with no drops.
