chrisr1
Nov 28, 2016Initiate
R7000 keeps dropping wifi connection
Hi, I have a Netgear R7000 router which I purchased 4 months ago. Recently it has been dropping the wifi connection intermittantly which seems to be getting worse, which is really annoying when try...
- May 04, 2017
Hi Garyr51,
Try to reset the router to factory default and reconfigure it manually. Change the channel of both 2.4Ghz and 5Ghz.
Hi PChell,
If your device is D7000, I would suggest posting it under DSL modem.
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
Garyr51
Mar 25, 2017Tutor
I am having the same problem with my 2 month old R7000. Every few days, the wifi drops on all my devices. Both 2.4 and 5ghz. The only thing that seems to correct it, is a router reboot. I did a chat with a support rep, (case number 28222817) he recommended changing the channels to 11 and 153. (2.4 and 5ghz). I did this two days ago, had the same issue this morning. I am seeing a lot of R7000 customers online with the same issue. Is this a faulty router??
PrimeNumber
Mar 27, 2017Guide
So, I ended up resetting the router by holding the reset button for 10 seconds. Before you do this, you may want to get your router up to the latest firmware. Resetting the router removed all settings and put it back to factory default, but left it at the latest firmware level. I went in an manually set everything up in the router again. I did NOT restore from a backup.
The router has been working fine for the past couple months since I have done this. I speculate that a cache or something was cleared in this process as all the settings I had before are now programmed in to the router. The only difference is that I get a continuous, strong WiFi signl all over the house with no drops.
- Garyr51Mar 31, 2017Tutor
I am still having the same problem. Wifi disconnects after about 2 days. Both 2.4 and 5ghz. I have tried the recommended channel changes, and a factory reset with a manual setup. Nothing seems to help. It dropped again yesterday. Had to reboot the router.
- Beamn1Apr 03, 2017Aspirant
I have had the same thing. Purchased the router in Mid January 17 and worked for two weeks without issue. Since then it's a continuous reboot of the router. This A.M. can't even download a 48MB file without wifi crash.
- JamesGLApr 06, 2017NETGEAR Employee Retired
Hi All,
What are the firmware version of your router? Make sure it is updated.
- JamesGLApr 09, 2017NETGEAR Employee Retired
Hi All,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- old_schoolApr 29, 2017Aspirant
I am having the same issue where wi if is dropping from iPads and wireless PCs. Few is V1.0.7.12_1.2.5. I getting very frustrating. Router is a couple years old. Sometimes a reboot fixes it. Some times it doesn't. Ready to buy something else I can depend on.
