chrisr1
Nov 28, 2016Initiate
R7000 keeps dropping wifi connection
Hi, I have a Netgear R7000 router which I purchased 4 months ago. Recently it has been dropping the wifi connection intermittantly which seems to be getting worse, which is really annoying when try...
- May 04, 2017
Hi Garyr51,
Try to reset the router to factory default and reconfigure it manually. Change the channel of both 2.4Ghz and 5Ghz.
Hi PChell,
If your device is D7000, I would suggest posting it under DSL modem.
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
PrimeNumber
Mar 27, 2017Guide
So, I ended up resetting the router by holding the reset button for 10 seconds. Before you do this, you may want to get your router up to the latest firmware. Resetting the router removed all settings and put it back to factory default, but left it at the latest firmware level. I went in an manually set everything up in the router again. I did NOT restore from a backup.
The router has been working fine for the past couple months since I have done this. I speculate that a cache or something was cleared in this process as all the settings I had before are now programmed in to the router. The only difference is that I get a continuous, strong WiFi signl all over the house with no drops.
Garyr51
Mar 31, 2017Tutor
I am still having the same problem. Wifi disconnects after about 2 days. Both 2.4 and 5ghz. I have tried the recommended channel changes, and a factory reset with a manual setup. Nothing seems to help. It dropped again yesterday. Had to reboot the router.
- Beamn1Apr 03, 2017Aspirant
I have had the same thing. Purchased the router in Mid January 17 and worked for two weeks without issue. Since then it's a continuous reboot of the router. This A.M. can't even download a 48MB file without wifi crash.
- JamesGLApr 06, 2017NETGEAR Employee Retired
Hi All,
What are the firmware version of your router? Make sure it is updated.
- JamesGLApr 09, 2017NETGEAR Employee Retired
Hi All,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- old_schoolApr 29, 2017Aspirant
I am having the same issue where wi if is dropping from iPads and wireless PCs. Few is V1.0.7.12_1.2.5. I getting very frustrating. Router is a couple years old. Sometimes a reboot fixes it. Some times it doesn't. Ready to buy something else I can depend on.
- Garyr51May 02, 2017Tutor
Still having the same issue. I updated the firmware to V1.0.7.12_1.2.5 , Since the update, I have wifi connection loss about once a week. Seems to be a bit better, but still unacceptable. I have to reboot the router to get wifi back.
- PChellMay 02, 2017Initiate
re-connected my TalkTalk router, no problems for 2 days now, confirmed connection problems definitely the Netgear router.
So router was posted back today for a full refund.
When I attempted registration it responded with already registered? So unable to get the 3 months customer support.
Not being a computer geek I just wanted something that worked... but it didn't.
- JamesGLMay 04, 2017NETGEAR Employee Retired
Hi Garyr51,
Hi PChell,
