chrisr1
Nov 28, 2016Initiate
R7000 keeps dropping wifi connection
Hi, I have a Netgear R7000 router which I purchased 4 months ago. Recently it has been dropping the wifi connection intermittantly which seems to be getting worse, which is really annoying when try...
- May 04, 2017
Hi Garyr51,
Try to reset the router to factory default and reconfigure it manually. Change the channel of both 2.4Ghz and 5Ghz.
Hi PChell,
If your device is D7000, I would suggest posting it under DSL modem.
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
Garyr51
Mar 31, 2017Tutor
I am still having the same problem. Wifi disconnects after about 2 days. Both 2.4 and 5ghz. I have tried the recommended channel changes, and a factory reset with a manual setup. Nothing seems to help. It dropped again yesterday. Had to reboot the router.
JamesGL
Apr 09, 2017NETGEAR Employee Retired
Hi All,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- old_schoolApr 29, 2017Aspirant
I am having the same issue where wi if is dropping from iPads and wireless PCs. Few is V1.0.7.12_1.2.5. I getting very frustrating. Router is a couple years old. Sometimes a reboot fixes it. Some times it doesn't. Ready to buy something else I can depend on.
